English
Error: Error in Reading Shape Record Length for Record . . .
Error Message
This error occurs when adding a shapefile to ArcView:
"Error in Reading Shape Record Length for Record . . ."
Cause
The shapefile is corrupted. Shapefiles can become corrupted if the $HOME and/or $TEMP directories full, or if they don't have enough disk space.
Solution or Workaround
1. Determine the settings for the $HOME and $TEMP environment variables.
A. Open a new view.
B. Select Add Theme from the View menu.
C. Replace the path in the Directory field with the environment variable, for example $HOME
D. Press the Enter key.
The Directory field will now show the actual path.
2. Make sure there is plenty of free space on the drive where the $HOME and $TEMP directories are located.
There should be 100 MB of free disk space.
3. Check the contents of the $HOME and $TEMP directories. Remove any un-needed files. If you do not wish to delete any of these files, you can rename the directory and create a new one. For example, rename c:\temp to c:\temp1 and then create a new c:\temp folder.
ArcView will perform optimally if each directory contains less than 100 MB of files.
Related Information
