HOW TO
Knowing the RGB values can be important for recreating these colors in other applications, such as ArcIMS.
Code:
'-- This script dumps colors from palette to layout
'-- RGB values are listed below each color.
thePalette = av.GetSymbolWin.GetPalette
symType = "color"
thePaletteList = thePalette.GetList(#PALETTE_LIST_COLOR)
numPages = (thePaletteList.Count / 60).Ceiling
pageCount = 0
symNum = 0
MakeNewPage = true
xp = 0
While (pageCount < numPages)
if (MakeNewPage) then
theLayout = Layout.Make
pageCount = pageCount + 1
end
MakeNewPage = false
theLayout.GetWin.open
theLayout.SetName(symType.UCase+((pageCount).AsString))
dis = theLayout.GetDisplay
dis.SetPageSize(8.5@11)
dis.SetMarginVisible(FALSE)
gl = theLayout.GetGraphics
'-- Make a bounding box
boundX = (750 - (8.50 / 2))
boundY = (750 + (11.00 / 2))
bboundX = (750 + (8.50 / 2))
bboundY = (750 - (11.00 / 2))
boundBox = Rect.MakeXY(boundX, boundY, bboundX, BBoundY)
gBoundBox = GraphicShape.Make(boundBox)
gl.AddBatch(gboundBox)
'-- Make framing box
topX = (750 - (8.50 / 2)) + 0.50
topY = (750 + (11.00 / 2)) - 0.50
botX = (750 + (8.50 / 2)) - 0.50
botY = (750 - (11.00 / 2)) + 0.50
box = Rect.MakeXY(topX, topY, botX, botY)
gbox = GraphicShape.Make(box)
gl.AddBatch(gbox)
dx = 1.25 'X distance change
dy = 0.99 'Y distance change
originX = 750 - (8.50 / 2)
originY = 750 + (11.00 / 2)
x = originX + 0.75
y = originY - 1.3
tX = x + 3.0
tY = originY - 0.75
tPt = (tX@tY)
gtPt = GraphicText.Make(symType+"s", tPt)
gl.AddBatch(gtPt)
'-- Create rectangle
xMin = x
yMin = y
xMax = x + 0.75
yMax = y + 0.5
r = Rect.MakeXY(xMin, yMin, xMax, yMax)
gr = GraphicShape.Make(r)
if (symType = "COLOR") then
for each ROW in 1..10
for each COLUMN in 0..5
nextRec = gr.Clone
nextRec.SetSymbol(av.GetSymbolWin.GetPalette.GetList(#PALETTE_LIST_FILL).Get(1).Clone)
nextRec.GetSymbol.SetColor(thePaletteList.GET(symNum).Clone)
rgb = nextrec.getsymbol.getcolor.getrgblist
r = "R "+rgb.get(0).asstring
g = "G "+rgb.get(1).asstring
b = "B "+rgb.get(2).asstring
offsetPt = (x@y)
nextRec.setOrigin(offsetPt)
pt = offsetPt + (0@0) - (0@0.25)
t = GraphicText.Make(r++g++b, pt)
ts = textsymbol.make
ts.setsize(9)
t.setsymbol(ts)
gl.UnselectAll
theLayout.GetGraphics.AddBatch(nextRec)
theLayout.GetGraphics.AddBatch(t)
x = x + dx
symNum = symNum + 1
if (symNum = thePaletteList.Count) then exit end
end 'for each COLUMN
x = originX + 0.75
y = y - dy
end 'for each ROW
if (symNum < ((thePaletteList.Count) - 1) ) then
MakeNewPage = true
end
end '-- Per Page
end '-- While
gl.UnSelectAll
av.GetProject.SetModified(true)
gl.EndBatch
Get help from ArcGIS experts
Download the Esri Support App
