English
Error: Error in image source [filename].sid
Error Message
This error occurs when adding a MrSid image as an image theme to a view:
Where is [filename].sid.
After dismissing that message, another is returned:
Error in image source [filename].sid. Unable to make theme.
Cause
The TEMP environment variable is set to a folder which is not 8.3 compliant. For example, 'TEMP = c:\documents and settings\users\local settings\temp' will evoke the problem.
Solution or Workaround
Change the TEMP environment variable to an 8.3 compliant directory. For example, c:\temp. See: How To: Edit an environment variable
