English
Error: Unable to load usage file. Unable to load Arc
Error Message
When starting Arcinfo, the following error is returned:
"Unable to load usage file. Unable to load Arc"
Cause
The path to the ARCHOME variable is set incorrectly or the TEMP and TMP variables have spaces in the path.
Solution or Workaround
  • Correct the path to ARCHOME. For UNIX, modify the .cshrc file for the user login.
  • Change the TEMP and TMP variables paths to a location that does not have spaces.
    For Windows, modify the system variables. See: How To: Edit an environment variable
