ERROR
Using the Select method on an IFeatureClass object causes a runtime error. For example, the following line would cause an error:
Set theSelection = pFeatureClass.Select(pQueryFilter, esriSelectionTypeIDSet, esriSelectionOptionNormal, pFeatureWorkspace)
This is a known issue.
This issue has been resolved for ArcGIS 8.1 and above.
Get help from ArcGIS experts
Download the Esri Support App
