English
FAQ: How do I display ArcSDE error messages in the local language using the ArcSDE 8.1 Java API?
Question
Answer
Contact your regional ESRI distributor to find out how you can obtain the ArcSDE 8.1 Java API Localization kit. You can use the localization kit to enable the localization of error messages returned from the ArcSDE server, and allow for the display of error messages in any desired language.
