HOW TO
Convert view graphics into a shapefile using Avenue
Summary
Instructions provided describe how to use Avenue to convert graphics, found in a view, to features in a shapefile.
Procedure
Run the following script on a view which contains graphics. If there are selected graphics, this script converts only those graphics. If there are no selected graphics, it converts all graphics of the selected type.
  1. Open a new script window.
    A. Activate the Project window.
    B. Click the Scripts icon.
    C. Click New.
  2. Copy the code into the new script window.
    Code:
    '-- Scriptgra2shp.ave
    '-- Converts all view graphics of the selected feature type into a shapefile,
    '-- then adds that shapefile to the View.
    theView=av.getactivedoc
    theGPL=theView.getgraphics.findallbyclass(GraphicShape)
    if (theGPL = nil) then msgbox.error("No graphic shapes in view","") return nil
    end
    theFTL={"Point", "Polyline", "Polygon"}
    aShapeType=msgbox.listasstring(theFTL, "Select the type of graphics you want"+
    "converted into a shapefile", "Choose a feature type")
    if (aShapeType = nil) then return nil end
    if (aShapetype = "point") then
    theclass = point
    elseif (aShapeType = "polyline") then
    theclass = polyline
    elseif (aShapeType = "polygon") then
    theclass = polygon
    end
    theCLoF={}
    for each g in theGPL
    if ((g.getshape.is(rect)) or (g.getshape.is(circle))) then
    g = graphicshape.make(g.getshape.aspolygon)
    end
    if (g.getshape.Is(theclass)) then
    theCLoF.Add(g)
    end
    end
    if (theCLoF.count = 0) then msgbox.error("No "+aShapeType+" graphic features in"+
    "view","") return nil end
    tmpfn = "c:\".asfilename.maketmp("test","shp")
    theOutFileName=FileDialog.Put(tmpfn,"*.shp","Create new shapefile from simple"+
    "graphics")
    theFtab=Ftab.MakeNew(theOutFileName, theclass)
    theIDfld=Field.Make("myID", #FIELD_LONG, 10, 0)
    theShapeFld=theFtab.FindField("Shape")
    theFldList={theIDfld}
    theFtab.AddFields(theFldList)
    for each fea in theCLoF
    theRecNo=theFtab.AddRecord
    theFtab.SetValue(theIDfld, theRecNo, theRecNo)
    eachShape=fea.getshape
    theFtab.SetValue(theShapeFld, theRecNo, eachShape)
    end
    theFTheme=Ftheme.Make(theFTab)
    theView.AddTheme(theFTheme)
    theView.Invalidate
  3. Compile the script by clicking the compile button.
    [O-Image] Script compile button
  4. Verify a view containing graphics is the active document. Execute the script by clicking the run button.
    [O-Image] Run compiled script button
Article ID:000002541
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
