English
Problem: Arcview crashes after start up
Left-clicking the File option in ArcView either crashes the ArcView window, or after it initializes, the window disappears and/or an error occurs (often a Segmentation Violation).
Cause
A conflict between Sun's Open Windows and the Common Desktop Environment (CDE).
Solution or Workaround
  1. Add the following line to the .cshrc file:
    Code:
    setenv OIT_LOOK_MOTIF
  2. Source the .cshrc, use Open Windows and restart ArcView.
    Do not set the OIT_WMGR
