English
Problem: Process history missing in ArcCatalog metadata
Metadata created using the DOCUMENT command in ArcInfo Workstation is not be reflected in ArcCatalog.
Cause
ArcCatalog is not able to get the history out of a coverage's log file and insert it into the metadata.
Solution or Workaround
  1. Export DOCUMENT metadata to a text file.
  2. Copy and paste the appropriate selections into ArcCatalog's metadata editor.
    [O-Image] metadata editor
    You should do this periodically since the metadata remains static
