ERROR
Microsoft Access driver could not find input table for query < name of table >
Error Message
This error occurs when clicking the Query button on the SQL Connect dialog box, after connecting to an Access database:
Microsoft Access driver could not find input table for query <name of table>
Cause
The name of the table and/or the field names in the table may contain space characters. You will not be able to add such a table to ArcView.
Solution or Workaround
  1. Open the database in Access.
  2. Check the table and column field names. Remove any space characters.
    Though underscores in a name are acceptable (Field_name), they are not recommended because some drivers may have problems with special characters.
    This is a Microsoft driver error, not an ArcView error.
Article ID:000002534
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
