PROBLEM
Large GRIDPOINT values are rounded
GRIDPOINT may round large numbers. For example, a value of 18,000,001 in a grid may become 18,000,000 in a coverage.
This document shows how to reapply the values before they were rounded from an integer grid.
Cause
This is a known issue with GRIDPOINT.
Solution or Workaround
  1. Add small unique identifier values to each record of the grid's VAT. For example, you can use the $RECNO (record number) of the VAT.
    Code:
    Tables: ADDITEM mygrid.vat newval 6 6 i
    Tables: SELECT mygrid.vat
    Tables: CALCULATE newval = $recno
  2. Convert the grid to a coverage based on this new value item.
    Code:
    Arc: GRIDPOINT mygrid mypoint newval
  3. Join the original VAT to the new PAT using the unique value item as the relate_item between them.
    Code:
    Arc: JOINITEM mypoint.pat mygrid.vat mypoint.pat newval
Article ID:000002521
Software:
  • Legacy Products
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
