Frequently asked question
Can I use indexes to improve the performance of Dynamic Segmentation?
Answer
Yes, you can. We recommend you use the following indexes:
· A spatial index on the route feature class
· An attribute index on the route key field
· An attribute index on the event key field
These indexes will significantly improve the performance of Dynamic Segmentation when you use Personal or ArcSDE geodatabases, and the improvement will be moderate when you use coverages and shapefiles.
Article ID:000002516
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
