English
Error: Fortran runtime error on external file "/path/gen_file" (-1):
Error Message
CREATETIN with a GENERATE file returns:
End of file reached
Bailing out of BRKTIN
Program failed to start or was killed
Cause
The ASCII generate file needs the END keyword as its last line.
Solution or Workaround
Open the generate file in an ASCII text editor and add END as the last line of the file. For an example, see Related Information.
Related Information
