English
How To: Use MapObjects objects without instantiating the map control
Summary
To use MapObjects objects without instantiating a map control while developing in Visual C++, use 'AfxOleInit()' to initialize your Ole DLLs.
Procedure
When you do not add a map control to your application, you will need to manually initialize some COM libraries.
Initialize the Ole DLLs by writing the following line of code into the event:
Code:
AfxOleInit();
