HOW TO
You can store and retrieve information about multiple items using a dictionary. The script in this document demonstrates how to create a legend classification using a dictionary.
Code:
'-- Unique Value Legend Example
'-- This script creates a Unique Values Legend and symbolizes
'-- the classes from sample data province.shp
theView = av.GetProject.FindDoc("View1")
theTheme = theView.GetActiveThemes.Get(0)
theLegend = theTheme.GetLegend
'-- First Set the LegendType
theLegend.SetLegendType(#LEGEND_TYPE_UNIQUE)
'-- Make the Unique Legend
theLegend.Unique(theTheme,"name")
thecolorpanel = av.getsymbolwin.getpalette.getlist(#PALETTE_LIST_COLOR)
thedictionary = dictionary.make(40)
theDictionary.add("Quebec",thecolorpanel.get(7))
theDictionary.add("Northwest Territories",thecolorpanel.get(9))
theDictionary.add("Nova Scotia",thecolorpanel.get(11))
theDictionary.add("Saskatchewan",thecolorpanel.get(13))
theDictionary.add("Alberta",thecolorpanel.get(15))
theDictionary.add("Newfoundland and Labrador",thecolorpanel.get(17))
theDictionary.add("British Columbia",thecolorpanel.get(19))
theDictionary.add("New Brunswick",thecolorpanel.get(21))
theDictionary.add("Prince Edward Island",thecolorpanel.get(23))
theDictionary.add("Yukon Territory",thecolorpanel.get(25))
theDictionary.add("Manitoba",thecolorpanel.get(27))
theDictionary.add("Ontario",thecolorpanel.get(39))
theDictionary.add("No data",thecolorpanel.get(41))
'-- Change the TOC and redraw the theme.
theClasses = thelegend.getclassifications
classclone = theclasses.clone
theSymbols = thelegend.getsymbols
classcount = {}
cont = theClasses.count - 2
for each i in classclone
theLabel = i.getlabel
if (thedictionary.get(thelabel) <> nil) then
if (thelabel <> "no data") then
classcount.insert(i.clone)
theclasses.remove(cont)
end
else
theSymbols.remove(cont)
end
cont = cont - 1
end
cont = 0
for each i in classcount
if (thelabel <>"no data") then
theClasses.insert(i)
theSymbols.get(cont).setcolor(thedictionary.get(thelabel))
cont = cont + 1
end
end
end
theTheme.UpdateLegend
'-- End of Script
The results of this Avenue code can be reproduce by Clicking the Load and Save legend button on the Legend editor.
Get help from ArcGIS experts
Download the Esri Support App
