English
Error: Oracle View deleted in ArcCatalog cannot be re-created with SDETABLE command
Error Message
SDETABLE returns an error message when an Oracle view has been deleted through ArcCatalog.
The following error message is returned when trying to re-create the Oracle view using the SDETABLE command:
Error: DBMS view exists (-238).
Error: Unable to create MV view states_vu for table states.
The following error message is returned when trying to delete the Oracle view using the SDETABLE command:
Error: DBMS table not found (-37)
Error: Unable to delete MV view for table states.
Cause
This situation occurs if you create a view in ArcSDE using the SDETABLE command and then delete the view with ArcCatalog.
Solution or Workaround
  1. Re-create the view from the SQLPlus prompt:
    Code:
    CREATE or REPLACE VIEW <insert name of the original view>
    AS SELECT * FROM <table name>;
  2. Delete the view using the SDETABLE command.
    SDETABLE can now be used to re-create the view.
