ERROR
Invalid SQL syntax
Error Message
ArcMap Error:
The Create Feature task could not be completed.
Invalid SQL syntax() [owner.tablename]
Cause
The sde.states table has become too large (too many rows). To process the Create Features task, ArcSDE queries this table; the resulting query statement exceeds an Oracle query size limitation.
Solution or Workaround
This issue was fixed in version 8.1, so the best solution is to upgrade. In the meantime it is possible to temporarily eliminate the error by following these steps:
  1. Back up the entire database.
  2. Compress the database.
  3. Execute the query.
Article ID:000002456
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
