English
Problem: ArcView help does not appear
When opening ArcView Help, the HyperHelp window appears, but the Help topics never load.
Cause
$HHHOME is not pointing to ArcView HyperHelp.
Solution or Workaround
  1. Set the $HHHOME variable to point to ArcView HyperHelp. Add the following to the .cshrc file:
    Code:
    setenv HHHOME /<path to ArcView HyperHelp directory>
  2. Source the .cshrc file:
    Code:
    % source .cshrc
