English
Problem: ArcMap Merge is greyed out when trying to merge arcs or polygons
When editing a layer in a coverage with topology, arcs or polygons cannot be merged because the Merge option is greyed out.
Cause
Merge is restricted to coverages without topology.
Solution or Workaround
  • To merge two arcs together, when topology is present:
    Select the shared node with the Shared Edit tool
    Shared edit tool icon is on the Editor toolbar
    [O-Image] Shared edit tool icon
    and delete it.
  • To merge two polygons together, when topology is present:
    Select the shared arc with the Shared Edit tool
    and delete it.
