The .PCODE file must have these items:
ITEM NAME WIDTH OUTPUT TYPE
FACODE 4 5 B
HEIGHT 4 5 B
FICODE 4 5 B
SMCCODE 4 5 B
NSTRUCT_PSK 2 5 B
PCT_TREE_COV 2 5 B
PCT_ROOF_COV 2 5 B
The .PCODE item FACODE must have values which are related to the DS<nnn>P-ID found in the .AAT. Appropriate values for the remaining items must be determined from the DFAD format specifications. See Related Information to find out how to obtain those specifications.
You could use AML to automate the creation of the .PCODE file.
/* NAME: PCODE.AML
/* USAGE: &RUN PCODE.AML
/* NOTES:
/* Run this AML from the Arc prompt.
/* Run this AML from a directory that is NOT the workspace
/* directory that will be converted with ARCDFAD
/* This is not an ESRI supported AML. Please use at your own risk.
/* Also, please make a backup of your data before running this AML
/* and carefully check the output. This is just a skeleton AML with
/* no real error checking. It is meant only as a guide to developing an
/* AML specific to your data inputs and desired outputs.
&args worksp incov
&sv orig_work = [show &workspace]
&workspace %worksp%
&if ^ [exist %incov% -cover] &then
&type Coverage %incov% not found.
&else
&do
tables
define %incov%.pcode
facode,4,5,b
height,4,5,b
ficode,4,5,b
smccode,4,5,b
nstruct_psk,2,5,b
pct_tree_cov,2,5,b
pct_roof_cov,2,5,b
quit
&end
&workspace %orig_work%
&return
The ArcInfo DFAD translator supports DFAD levels 1, 2, 1-C, and 3-C only. Check with your data provider to determine what DFAD level you have.
