English
FAQ: Did the default setting of UseDefault property change at version 2.0?
Question
Answer
Yes. At MO 1.x, the default setting of the LabelPlacer's UseDefault property was "False". At 2.0, the default setting is "True", so legacy code might show different behavior if were depending on the default setting being "False".
