English
FAQ: Are Designer Forms supported in VBA for ArcGIS?
Question
Answer
No. You can not create or add Designer Forms to VBA for ArcGIS. Although in versions 8.0.1 and 8.0.2 you are able to add Designer Components to the Insert menu, they remain grayed out. The ability to add Designer Components to the Insert menu has been removed at version 8.1 to avoid confusion.
