HOW TO
Load data into ArcMap at startup
Last Published: April 26, 2020
Summary
You can add VBA code to the MxDocument's NewDocument event, so when ArcMap starts without referencing an existing document.mxd, the NewDocument event code will be executed.
Procedure
  1. Start the Visual Basic Editor.
    In ArcMap, select Tools > Macros > Visual Basic Editor.
  2. In the View menu > Properties window, open the code for Normal > Arcmap Objects > ThisDocument.
  3. At the top of the Normal.mxt - ThisDocument (Code) window, choose MxDocument as the object and NewDocument as the event.
  4. Add code to load data into the ArcMap document
    See: HowTo: Add feature classes to ArcMap using VBA
Article ID:000002362
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
