English
Error: ORA-00001: unique constraint (AA.UK_AS_xxx) violated
Error Message
This error occurs when using the sdelayer command like this:
sdelayer -o register -l GD_AS_EISENBAHN,geometry -e sl -c gid -k SDO_GEOMETRY -u aa -p aa
The complete error is:
ArcSDE 8.0.2
Layer Administration Utility
Error: Underlying DBMS error (-51).
Error: Unable to alter registration for table GD_AS_EISENBAHN
Error: External table cannot be registered.
ORA-00001: unique constraint (AA.UK_AS_EISENBAHN) violated
ORA-06512: at line 1
Cause
An attempt to register an Oracle spatial layer with name greater than 14 characters long violates SDE layer name unique constraint (truncating name).
Solution or Workaround
Shorten the table name to 14 characters or less.
