English
Error: bad login user unable to start iomgr
Error Message
Attempting to start ArcSDE with sdemon -o start may produce this error:
Cause
This error will occur if the user attempting to start ArcSDE is not the user who installed the software. It can also be caused by placing $SDEHOME/bin towards the end of the path definition.
Solution or Workaround
  • Make sure you are logged in as the user who installed ArcSDE. This will allow you to successfully execute sdemon -o start.
  • Place $SDEHOME/bin before the other entries in the path definition. You should also place $SDEHOME/lib at the beginning of the shared library path definition.
