English
Error: load_buffer (-51)
Error Message
This error is returned in the sde.errlog when panning, zooming, or querying a registered Oracle spatial layer:
load_buffer (-51)
Cause
The error is the result of an invalid MDSYS.SDO_DIM_ELEMENT. Refer to the Oracle documentation for more information about this parameter.
Solution or Workaround
Change MDSYS.SDO_DIM_ELEMENT Extent values based on Oracle calculations or a best guess. You can use the Oracle tool SDO_TUNE.EXTENT_OF to determine the minimum bounding rectangle of the data in a layer.
SQL example for an SDO layer that fails:
Code:
CREATE TABLE cultitem(
CULT_ITEM_INDX NUMBER(6) NOT NULL,
CULT_SET_CHVN VARCHAR2(6) NOT NULL,
GEOMETRY MDSYS.SDO_GEOMETRY);
INSERT INTO cultitem VALUES (940,'BBQ459',MDSYS.SDO_GEOMETRY(
2003,NULL,NULL,
MDSYS.SDO_ELEM_INFO_ARRAY(1, 3, 1),
MDSYS.SDO_ORDINATE_ARRAY(
-97.11661, 29.6236114, -97.13016, 29.6233806, -97.129929, 29.6014086,
-97.116456,
29.6016074, -97.11661, 29.6236114)));
INSERT INTO USER_SDO_GEOM_METADATA
values(
'CULTITEM','GEOMETRY',
MDSYS.SDO_DIM_ARRAY(
MDSYS.SDO_DIM_ELEMENT('X', -180, 180, 0.000000005),
MDSYS.SDO_DIM_ELEMENT('Y', -90, 90, 0.000000005)
NULL -- SRID (reserved for future Spatial releases)
commit;
CREATE INDEX cultitem_hybrid ON CULTITEM(GEOMETRY)
INDEXTYPE IS MDSYS.SPATIAL_INDEX PARAMETERS('SDO_LEVEL=10
SDO_NUMTILES=2');
sdelayer -o register -l cultitem,goemetry -e a -c cult_item_indx
-k sdo_geometry -S "Culture Item Oracle Spatial" -u hhwa -p pwd
SQL examples that work:
Code:
2003,NULL,NULL,
MDSYS.SDO_ELEM_INFO_ARRAY(1,3, 1),
29.6014086,
-97.116456,
values(
MDSYS.SDO_DIM_ELEMENT('X', -100, 0, 0.0000005),
MDSYS.SDO_DIM_ELEMENT('Y', 0, 90, 0.0000005)
commit;
CREATE INDEX cultitem_fixed ON CULTITEM(GEOMETRY)
INDEXTYPE IS MDSYS.SPATIAL_INDEX PARAMETERS('SDO_LEVEL=8');
Code:
CREATE TABLE cola_markets ( mkt_id NUMBER(6) NOT NULL, name VARCHAR2(32),
shape MDSYS.SDO_GEOMETRY);
INSERT INTO cola_markets VALUES( 2, 'cola_b', MDSYS.SDO_GEOMETRY( 2003, NULL, NULL, MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,1),
MDSYS.SDO_ORDINATE_ARRAY(5,1, 8,1, 8,6, 5,7, 5,1) ) );
INSERT INTO cola_markets VALUES( 3, 'cola_c', MDSYS.SDO_GEOMETRY( 2003, NULL, NULL, MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,1),
MDSYS.SDO_ORDINATE_ARRAY(3,3, 6,3, 6,5, 4,5, 3,3) ) );
INSERT INTO USER_SDO_GEOM_METADATA VALUES
( 'cola_markets', 'shape', MDSYS.SDO_DIM_ARRAY( MDSYS.SDO_DIM_ELEMENT('X', 0, 20, 0.005),
MDSYS.SDO_DIM_ELEMENT('Y', 0, 20, 0.005) ), NULL);
CREATE INDEX cola_spatial_idx ON cola_markets(shape) INDEXTYPE IS MDSYS.SPATIAL_INDEX PARAMETERS('SDO_LEVEL = 8');
sdelayer -o register -l ,shape -k SDO_GEOMETRY -c mkt_id -i sde8ora8i -u test -p test
