ERROR
-33 Invalid grid size
Error Message
This error occurs when attempting to register an Oracle Spatial 'external (in-line table (layer)):
Example:
> C:\>sdelayer -o register -l parcels,geom -e a+ -c id_field -i sde802 -u
sdo_user
> -p sdo_user
> ArcSDE 8.0.2
> Layer Administration Utility
> Error: Invalid grid size (-33).
> Error: Cannot Create Layer.
Cause
The SDO_GEOMETRY keyword was not used, nor was the DEFAULTS geometry storage type set to SDO_GEOMETRY. SDEBINARY was the default storage type.
Solution or Workaround
Change to use SDO_GEOMETRY:
sdo_user
> -p sdo_user -k sdo_geometry
> ArcSDE 8.0.2
> Successfully Created Layer.
Article ID:000002333
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
