English
How To: Run an aml at a specified date and time on UNIX
Summary
Steps to automate the execution of an aml at a specified date and time.
Procedure
  1. Create a shell script, name it something like 'runaml.scr', insert and modify the following lines to run your aml:
    #!/bin/csh
    setenv ARCHOME /your_path_to_ARCHOME
    setenv LD_LIBRARY_PATH /your_path_to LD_LIBRARY
    $ARCHOME/bin/arc '&r /filepath/your.aml' > output.file
    Specifying an output file frees the screen from AML output.
  2. Make the shell script executable:
    Code:
    unix>chmod 777 filename
  3. Create a crontab file:
    Code:
    unix>crontab -e
    For this to work, you need to define the EDITOR variable either at the system prompt or in your .cshrc file:
    setenv EDITOR your_favorite_editor
  4. Insert the date, time, and name of the script file to be executed. The following example executes 'runaml.scr' at 10:00pm every Tuesday:
    0 20 * * 2 /your_file_path/runaml.scr
    For additional information, type "man crontab" at the UNIX prompt.
Related Information
