PROBLEM
SDE layers load slowly
Poor performance is experienced when loading SDE layers. This can also occur when loading shapefiles with .PRJ files.
Cause
This is a result of additional checks made for the NADCON grid files. These files install in the PE_Grids folder under C:\Program Files\Common Files\ESRI.
Solution or Workaround
Rename or delete the PE_Grids folder if NADCON support is not required for projections.
At MapObjects 2.0a, when the PE_Grids folder is not present, the checks are omitted and performance is greatly improved.
For more information, refer to ReadMeMO20a.doc in the \Program Files\ESRI\MapObjects folder.
Article ID:000002306
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
