English
Error: No execute privilege for required Oracle builtin package DBMS_PIPE
Error Message
On a machine running Windows NT 4.0 with Service Pack 6a, and Oracle 8.1.6, this error occurs when starting ArcSDE 8.1 Beta 2 for the first time:
Starting ArcSDE 8.1
Received the following in sde.errlog:
ArcSDE 8.1 for Oracle8i Build 586 Thu Aug 24 09:26:13 PDT 2000
DBMS Connection established...
No execute privilege for required Oracle builtin package DBMS_PIPE.
ERROR: Cannot Initialize Shared Memory (-404)
Cause
ArcSDE user has inadequate permissions.
Solution or Workaround
Grant the following permissions to your ArcSDE user:
A. Select any table
B. Create any sequence
C. Create any procedure
D. Drop any procedure
E. Execute any procedure
