English
How To: Create a directory using Avenue
Summary
You can use the system.execute() request to send commands from ArcView to the Operating System.
Procedure
  • Option 1: The following line has a hardcoded pathname of the directory to be created. Insert it into your script, edit it as necessary, compile it, and run it:
    Code:
    System.Execute("c:\winnt\system32\command.com /c mkdir drive:\pathname")
  • Option 2: The following code prompts you for the pathname of the directory to be created. Insert it into your script, edit it as necessary, compile it, and run it:
    Code:
    newDirectory = MsgBox.Input("c:\gis\data", "Create Directory", "")
    System.Execute("c:\winnt\system32\command.com /c mkdir"++newDirectory)
    You may need to do a Find to determine where command.com is located on your system.
    For extended pathnames, make sure the directories preceding the one you want to create already exist.
