PROBLEM
When an image has been loaded into the Map Control, MapObjects' PrintMap, OutputMap, and OutputMap2 methods occasionally produce output with poor image resolution.
This occurs when printing to an HP 5Si or HP 5Si MX printer and MapObjects is running on Windows 95 or Windows 98.
Possible problem with the printer driver.
Experiment with a different printer driver. In some cases an HP4 printer driver has produced good quality output resolution.
See your System Administrator for assistance with printer drivers. You may also download a driver from the HP Web site; see link below.
Get help from ArcGIS experts
Download the Esri Support App
