PROBLEM
While installing Crystal Reports for ESRI, the setup prompt you for a registration number.
The registration number for Crystal Reports should be provided automatically by the setup process. On some systems this fails to work properly. You will need to manually enter the registration number.
Get help from ArcGIS experts
Download the Esri Support App
