English
How To: Export the Legend as a Bitmap in VC++
Summary
This document contains sample code to demonstrate how to export the MapObjects legend control as a bitmap.
Procedure
  1. Create a variable to store the index number of the layer to be exported.
    Use -1 to add all layers to the bitmap of the Legend.
    Code:
    short i = -1;
  2. Create a variable to store the path and location of the bitmap.
    Code:
    BSTR str = SysAllocString(L"C:\\temp\\temp.bmp");
  3. Export the Legend as a BMP file
    Code:
    m_legend.ExportToBmp(&str, &i);
