English
How To: Deploy a MapObjects application that supports ERDAS images
Summary
To deploy a MapObjects application that supports ERDAS images, you must deploy all of the necessary image components.
Procedure
ERDAS .gan and .lis files require only the standard set of image components that are listed in the deployment chapter of 'Building Applications with MapObjects'.
In addition to the standard image components, ERDAS IMAGINE (.img) files require:
1. The entire contents of the MO_image\Devices folder
2. The img.dll file in the MO_image\Usr\Lib\NTx86\RasterFormats folder
Retain the folder-naming convention when you deploy these additional files.
Related Information
