HOW TO
Convert GeoDatabase to single precision coverage in Desktop ArcInfo
Summary
The ArcToolbox Geodatabase to Coverage tool creates a single precision coverage even though the input is a double precision coverage. These steps will allow you to maintain the original double precision coordinates.
Procedure
  1. Use the ArcToolbox GeoDatabase to Shapefile tool to create a shapefile.
  2. Use the Arc PRECISION command to set the precision environment to DOUBLE DOUBLE.
  3. Use the Arc SHAPEARC command to create a double precision coverage.
Article ID:000002265
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
