ERROR
Error extracting (Name)
Error Message
Business Analyst returns this error when you extract map data and a summary of the attributes, or when you extract map data and all attributes from the CD:
Error opening dac
Cause
The dataset specified during the installation of Business Analyst is not one that was purchased. For example, the AGS data set was specified and the data set purchased was CACI.
Solution or Workaround
  1. Un-install Business Analyst
  2. Reinstall Business Analyst
  3. Specify the correct data set
    The data set you purchased is printed on the ArcView Business Analyst Data Volume 1 CD.
Article ID:000002263
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
