English
Error: This instance's service name &ltinstance> not found in system services file
Error Message
When sdemon -o start is used to start ArcSDE, the following error appears:
"This instance's service name <instance> not found in system services file."
Cause
There are a number of possible causes for this behavior. The causes and solutions are listed below.
Solution or Workaround
Causes and solutions are listed in order of probability.
  • Check TCP/IP services file configuration of the ArcSDE application server.
    <a href='http://support.esri.com/en/knowledgebase/techarticles/detail/35476' target='_blank'>How To: Check TCP/IP services file configuration of the ArcSDE application server</a>
  • When using Windows systems, the TCP/IP component may be corrupted. Reinstall the TCP/IP component. Refer to the Windows documentation or Microsoft support site for details on how to do this.
Related Information
