ERROR
ORA-01114: IO error writing block to file
Error Message
These errors occur when attempting to use Oracle data files; similar errors are displayed in SQLplus when attempting to manually build a simple index on a table:
SDE Error(-51) Underlying DBMS error
Extended error code (1114): ORA-01114: IO error writing block to file 3
(block # 263)
ORA-274041: unable to open file
SVR4 Error: 13: permission denied
Additional information: 3
ORA-01114: IO error writing block to file 3 (block # 263)
(GIS.F2_PK)
Not able to set layer into Normal-IO mode.
Cov2SDE completed
Cause
You don't have execute permission (UNIX file system) on the directory containing the Oracle data files, whose tablespaces the you are trying to use.
Solution or Workaround
Use the UNIX chmod command to give all users execute permission to the directory containing the Oracle data files:
Code:
%unix> chmod o+x data_directory
Article ID:000002227
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
