English
Problem: Viewer installation window keeps displaying
I am having problems with the ArcIMS Viewer installation on the client computer. The first time I access ArcIMS on a new computer, I am prompted to install the viewer. Every time after it is installed, ArcIMS wants to reinstall it and prevents me from viewing the ArcIMS web page. What is the problem?
Cause
JRE was not highlighted during the ArcIMS Viewer installation.
Solution or Workaround
During the ArcIMS Viewer installation, a screen asks you to "Choose the location of the JRE". You need to highlight the JRE.
· For example, for ArcIMS 3.0, highlight <drive>:\Program Files\JavaSoft\JRE\1.2\bin\java.exe
· For example for ArcIMS 3.1, highlight <drive>:\Program Files\JavaSoft\JRE\1.3\bin\java.exe
Highlight the correct JRE with the mouse and then click Install.
