English
Problem: getVersion doesn't work for Netscape or iPlanet Web servers
I’m having problems using iPlanet and Netscape Enterprise Web Server with ArcIMS. When I try getVersion in my browser, I don’t get the correct response. Why?
Cause
For both iPlanet and Netscape, the Esrimap_prop file should be in Netscape’s config directory rather than the servlets directory.
Solution or Workaround
  • For iPlanet, move the Esrimap_prop file from \Netscape\server\docs\servlet to \Netscape\server4\https<localhost>.<domain>.com\config.
  • For Netscape, move the Esrimap_prop file from \Netscape\SuiteSpot\plugins\Java\servlets to \Netscape\SuiteSpot\https-<localhost>.<domain>.com\config.
