ERROR
Method 'CoordinateSystem' of object '_DMap' failed.
Error Message
When attempting to assign a ProjCoordSys object to the CoordinateSystem property of a Map or MapLayer object, the following error may occur:
Cause
This error may occur if the ProjCoordSys object's Type property has been set equal to the Type property of another ProjCoordSys object. For example, code like this sometimes raises the error:
Dim mapPCS As New MapObjects2.ProjCoordSys
mapPCS.Type = Map1.Layers(0).CoordinateSystem.Type
Map1.CoordinateSystem = mapPCS
Solution or Workaround
Don't pass the Type property. Set the new ProjCoordSys object equal to the layer's ProjCoordSys explicitly. For example,
Code:
Set mapPCS = Map1.Layers(0).CoordinateSystem
Set Map1.CoordinateSystem = mapPCS
Article ID:000002141
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
