HOW TO
This document describe how to configure a Solaris machine with a 24-bit Creator 3D graphics card to use 24-bit color depth.
Code:
xdpyinfo
Examine the 'Root Visual Depth' within the 'Default Visual' parameter. You will need to modify the file /usr/dt/config/Xservers to adjust this setting to 24-bit color depth.
Code:
-dev /dev/fb defdepth 24 defclass TrueColor
Code:
xdpyinfo
Root Visual Depth should report a 24-bit color depth.
Get help from ArcGIS experts
Download the Esri Support App
