English
Problem: Can't edit shapefiles that were converted from CAD themes
The Start Editing option is grayed out for a theme that was created by converting a CAD theme to a shapefile.
Cause
Two possible causes:
1. The shapefile stores 3D features.
2. The original CAD file had blocked entities.
Solution or Workaround
  • Convert the 3D feature theme into a 2D feature theme using the xyz2xy.ave sample script located in ..\Av_gis30\ArcView\Samples\Scripts.
  • Explode the CAD file using the file's native CAD application.
    ArcView cannot edit 3D feature themes unless the 3D Analyst extension is loaded.
