Error Message
Starting ArcInfo Workstation returns this message:
Procedure entry point rdcell could not be located in dynamic link library aigridio.dll
Cause
The system PATH variable is set incorrectly. There may be either older arcexe or Imagine entries preceding the current arcexe80\bin and \lib entries.
Solution or Workaround
Remove the older arcexe entries. If there are Imagine entries, place the arcexe80 entries before them.
Windows NT:
A. Click Start > Settings > Control Panel.
B. Double-click the System icon.
C. Click the Environment tab.
D. Select Path from the System Variables.
E. Edit the variable definition in the Value text box.
UNIX:
Open the .cshrc file in a text editor and edit the value of the PATH variable.
It is also possible to set it manually at the UNIX prompt for the duration of a given command window by typing:
Code:
set PATH = ( value_of_variable )
This error can also occur on older versions of ArcInfo.
