English
How To: Calculate the maximum difference between a grid cell and it's neighbours
Summary
Using a 'kernal file' will restrict the analysis to the neighbours surrounding the cell currently being processed. Some simple mathematical evaluations will lead to the final result.
Procedure
  1. Create a text file (any_name.txt) with the following four lines:
       3 3
    1 1 1
    1 0 1
    1 1 1
    Make sure you type a return after the last number.
  2. Determine the maximum and and minimum values around the cell.
    Code:
    Grid: fmax = FOCALMAX (in_grd, IRREGULAR, donut.txt)
    Grid: fmin = FOCALMIN (in_grd, IRREGULAR, donut.txt)
  3. Determine the difference between the cell and the max/min values.
    Code:
    Grid: diffmax = ABS (fmax - in_grd)
    Grid: diffmin = ABS (in_grd - fmin)
  4. Assign the maximum difference to the output grid.
    Code:
    Grid: finaldiff = MAX (diffmax, diffmin)
