ERROR
FATAL ERROR Segmentation Violation
Last Published: April 26, 2020
Error Message
The following error occurs when starting ArcInfo:
Error:
FATAL ERROR
Cause
There may be syntax or typographic errors in the license file, such as a missing underscore or secondary encryption string in a FEATURE line.
Solution or Workaround
  1. Compare the license file with the license file received from ESRI.
  2. Make sure you have the proper syntax.
    Example: missing underscore (vendor_info):
    Incorrect:
    Code:
    FEATURE ARC/INFO ESRI 8.01 01-jan-00 1 3BFF602151F669CB9349 vendor info="8CDZFL7B5R6G6RH9L023" ck=15
    Correct:
    Code:
    FEATURE ARC/INFO ESRI 8.01 01-jan-00 1 3BFF602151F669CB9349 vendor_info="8CDZFL7B5R6G6RH9L023" ck=15
    Example: missing secondary encryption string:
    Incorrect:
    Code:
    FEATURE ARC/INFO ESRI 8.01 01-jan-00 1 3BFF602151F669CB9349 vendor_info="" ck=15
    Correct:
    Code:
  3. Stop and start the license manager.
    Windows: See: How To: Stop or Start the Arcinfo License Manager on Windows
Article ID:000002082
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
