Summary
Storing custom colors can streamline your organization's common mapping requirements.
Here are the steps to add a custom color to a Style set.
Procedure
- Open Styles > Style Manager from the Tools menu.
- Select the target Style on the Style Manager table of contents.
- Click the plus symbol (+) to the left of the Style to display its sub-folders.
- Select the Colors sub-folder.
- Right-click on the Content Window (right hand side of the Style Manager).
- Click New on the popup menu and select a color scheme (RGB, CMYK, HSV, Gray, Name).
- Define the desired color on the Select Color Dialog and click OK.
- Rename the new color, if desired, in the Contents portion of the Style Manager.
