English
How To: Manage the Application Server from the command line for ArcIMS 3.0
Summary
You can start, stop, add, and delete MapServices, Spatial Servers, and Virtual Servers from the command line.
Procedure
  • To manage the ArcIMS Application Server from the command line, first open a command prompt. From the command prompt you will use the following syntax:
    Code:
    java com.esri.aims.admincore.cmd.Exec <url> <user> <pword> <options> <commands>
    Where:
    url = http://host_web_server - Example: http://corleone
    user = login user name
    pword = login password
    options = cmd {used to specify an information tag follows}
    file {a file containing predefined commands}
    commands = filename or command to process:
    SERVICE - Gets all services
    VSERVER - Gets all Virtual Servers
    PSERVER - Gets all Physical (Spatial) Servers
    STATS - Gets stats for all Virtual Servers
  • The following examples show how to:
    Get Statistics:
    Code:
    > java com.esri.aims.admincore.cmd.Exec http://corleone admin admin cmd STATS
    Get Services:
    Code:
    > java com.esri.aims.admincore.cmd.Exec http://corleone admin admin cmd SERVICE
    Get Virtual Servers
    Code:
    > java com.esri.aims.admincore.cmd.Exec http://corleone admin admin cmd VSERVER
    Get Physical (Spatial) Servers
    Code:
    > java com.esri.aims.admincore.cmd.Exec http://corleone admin admin cmd PSERVER
  • The same command line syntax can be used to process XML batch files. The following illustrates how to do this with the sample testAddandStartService.xml and testStopandRemoveService.xml files:
    Code:
    > java com.esri.aims.admincore.cmd.Exec http://corleone admin admin file testAddandStartService.xml
    Here is the testAddandStartService.xml file:
    <?xml version="1.0" encoding="Cp1252"?>
    <ADMINCMD VERSION="0.1">
    <SERVICES>
    <SERVICE TYPE="ADD"
    NAME="WORLD1"
    AXL="c:\ArcIMS\Axl\world.axl"
    VSNAME="ImageServer1"
    IMGLOC="c:\arcims\output"
    IMGURL="http://corleone/output"
    CLEANUP="5"
    IMGTYPE="PNG"
    <SERVICE TYPE="START"
    NAME="WORLD1"
    <SERVICE TYPE="ADD"
    NAME="WORLD2"
    VSNAME="FeatureServer1"
    CLEANUP="5"
    IMGTYPE="PNG"
    NAME="WORLD2"
    <SERVICE TYPE="ADD"
    NAME="WORLD3"
    CLEANUP="5"
    IMGTYPE="PNG"
    NAME="WORLD3"
    <SERVICE TYPE="ADD"
    NAME="WORLD4"
    CLEANUP="5"
    IMGTYPE="PNG"
    NAME="WORLD4"
    </SERVICES>
    </ADMINCMD>
    Code:
    > java com.esri.aims.admincore.cmd.Exec http://corleone admin admin file testStopandRemoveService.xml
    Here is the testStopandRemoveService.xml file:
    <SERVICES>
    <SERVICE TYPE="STOP" NAME="WORLD1" />
    <SERVICE TYPE="REMOVE" NAME="WORLD1" />
    <SERVICE TYPE="STOP" NAME="WORLD2" />
    <SERVICE TYPE="REMOVE" NAME="WORLD2" />
    <SERVICE TYPE="STOP" NAME="WORLD3" />
    <SERVICE TYPE="REMOVE" NAME="WORLD3" />
    <SERVICE TYPE="STOP" NAME="WORLD4" />
    <SERVICE TYPE="REMOVE" NAME="WORLD4" />
    </SERVICES>
    </ADMINCMD>
    Click below to see the XML batch file syntax for managing:
    - Services (SERVICE)
    <SERVICES>
    <SERVICE TYPE={ ADD | CHANGE | REMOVE | START | STOP }
    NAME="WORLD1"
    AXL={Any valid axl file e.g. "c:\ArcIMS\Axl\world.axl"}
    VSNAME={Any valid Virtual Server name e.g. ImageServer1}
    CLEANUP={integer number}
    IMGTYPE={ PNG | GIF | JPG }
    </SERVICES>
    </ADMINCMD>
    - Physical (Spatial) Servers (PSERVER)
    <PSERVERS>
    <PSERVER TYPE={ ADD | REMOVE }
    ID={ unique id for this machine - usually added for you }
    MACHINE={ any machine that has monitor running on it }
    THREADS={ integer number of threads - used for virtual servers only }
    </PSERVERS>
    </ADMINCMD>
    - Spatial Servers (VSERVER)
    <VSERVERS>
    <VSERVER TYPE={ ADD | CHANGE | REMOVE }
    NAME={ Name of VSERVER }
    SERVICETYPE={ any valid server component (e.g. ImageServer) }
    <PSERVER ID={ ServerID } THREADS={ n } />
    </VSERVERS>
    </ADMINCMD>
