English
Problem: I receive a box asking for a password when starting Maplex
I receive a box asking for a password when I start Maplex.
Cause
Maplex is unable to find the hardware key.
Solution or Workaround
  • Make sure the Maplex hardware key is plugged into the back of the machine where Maplex is installed.
  • Run the Sentinel Driver Setup program.
    <a href='http://support.esri.com/en/knowledgebase/techarticles/detail/14617' target='_blank'>How To: Install the Sentinel key driver for Maplex</a>
